10 years ago
USB Blaster 2 + MAX10 - TCK / programming issue
I've designed a MAX10 10M02SCE144I7G board to be programmed with JTAG. Programming device is Altera USB Blaster II. When I try programming with Quartus Prime, it says:
Error (209040): Can't access JTAG chain
Error (209012): Operation failed
TCK is pulled down with 10k,
TMS and TDI are pulled up with 10k
I've checked TCK signal with an oszilloscope, showing a broken signal, see attached pictures.
To verify, I've tryed connecting directly onto USB blaser: GND and +3V3 (VCC TARGET) pins (1,10 & 4) + TCK pin pulled down with 1kOhm (so no connection to my board), the TCK clock still shows the same weird behaviour.
A 2nd. USB Blaster is showing the same pattern.
Can somebody please help me identifying the problem?
Attachment: TCK signal when pressing "Start" in the Quartus Prime Programmer, zoomed in and complete view.
