14 years agourjent logarithm implementation
sir, i want to design logarithm in vhdl.i get a formula i.e ln(a) = 2* atanh ((a-1)/(a+1)). but not quite sure.can u plz give some idea of easy implementation (not using core) orsome alternate formul...
14 years agolibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity logarithm is Port ( clock : in STD_LOGIC; ip_bit : in STD_LOGIC_VECTOR (13 downto 0); log_ot : out STD_LOGIC_vector(13 downto 0)); end logarithm; architecture Behavioral of logarithm is component ipcore_arctanh is Port ( x_ip : in STD_LOGIC_VECTOR (15 downto 0); y_ip : in STD_LOGIC_VECTOR (15 downto 0); x_op : out STD_LOGIC_VECTOR (7 downto 0); clock : in STD_LOGIC); end component; component fpdiv is Port ( diva : in STD_LOGIC_VECTOR (15 downto 0); divb : in STD_LOGIC_VECTOR (15 downto 0); ---div0 : out STD_LOGIC; divq : out STD_LOGIC_VECTOR (15 downto 0)); end component; signal b,q,s,t : integer; signal l1,l2,l3 : std_logic_vector (15 downto 0); signal l :std_logic_vector (7 downto 0); signal p :std_logic_vector (15 downto 0) := "0000000000000001"; begin l1 <= ip_bit - '1'; l2<= ip_bit +'1'; k1:fpdiv port map (l1,l2,l3); k2 : ipcore_arctanh port map (p,l3,l,clock); b <= conv_integer (unsigned(l)); q<= (2*b); log_ot <= conv_std_logic_vector(q,14); end Behavioral; this is my code in vhdl,but in simulation it gives '0' for any input given. is there any logic mistake. plz help.
