15 years agoURGENT: Peripheral to Memory DMA Transaction
Hello, may I know how to transfer data from peripheral to memory using DMA? It is quite confusing from memory-to-memory transfer. please help! thanks!
15 years agoWhen transferring data from peripheral to SDRAM using DMA. My code is as followed:
--- Quote Start --- #include "io.h"# include <stdio.h># include <unistd.h># include <sys/alt_dma.h># include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "system.h"# include "sys/alt_timestamp.h" static volatile int rx_done = 0; static void transfer_done (void* handle, void* data) { rx_done++; } void mem2mem_DMA(unsigned int dst, int length) { void *rx_data = (void *) dst; alt_dma_rxchan rxchan; int ret_code; int i; int x[100]; for(i=0;i<100;i++) { IOWR(ADDER_0_BASE,0,1); /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/dma")) == NULL) { printf("Failed to open receive channel\n"); exit (1); } ret_code = alt_dma_rxchan_ioctl(rxchan, ALT_DMA_SET_MODE_32, NULL); if (ret_code) { printf("Error: SET_MODE_32: %d.\n", ret_code); exit(1); } ret_code = alt_dma_rxchan_ioctl(rxchan, ALT_DMA_RX_ONLY_ON, (void*)(ADDER_0_BASE)); if (ret_code) { printf("Error: ALT_DMA_RX_STREAM_ON: %d.\n", ret_code); exit(1); } /* Post the receive request */ if ((ret_code = alt_dma_rxchan_prepare(rxchan, rx_data, length, transfer_done, NULL)) < 0) { printf("Failed to post read request, reason = %i\n", ret_code); exit (1); } } /* wait for transfer to complete */ while (!rx_done); printf("Transfer successful!\n\n"); } int main(void) { printf("\nThis is 32bits addition operation \n\n"); unsigned int dst = SDRAM_BASE + 0x600000; unsigned x[150]; //unsigned long output1[100]; int i=0; int w; mem2mem_DMA(dst, 100); for(i=0; i<100; i++) { printf("%d\n",IORD(dst, i)); } return 0; } --- Quote End ---
