15 years agoURGENT: Flash memory
Hello. I am doing a project regarding DMA. However I need to use flash memory on the DE2 Board. I have done the instantiation for the flash but I cannot use because it always return zero for the func...
15 years agoSir,
Thanks for the reply. My settings are also same like you. Even though it is not working. I am using Custom Board with 1MB Flash attached. My setting in SOPC: Address Width: 20-bit Data Width: 8-bit Timing: Setup: 45 Wait: 160 Hold: 45 Unit: ns Already added in Avalon MM Tristate Bridge. For 1MB i am using 20-bit and you are using 22-bit for 8MB. Is their any mistake here? Srinivas M
