15 years agoURGENT: Flash memory
Hello. I am doing a project regarding DMA. However I need to use flash memory on the DE2 Board. I have done the instantiation for the flash but I cannot use because it always return zero for the func...
15 years agoI am using Altera DE2 Board with 4MB Flash attached.
My setting in SOPC: Address Width: 22-bit Data Width: 8-bit Timing: Setup: 40 Wait: 160 Hold: 40 Unit: ns Remember to add in Avalon MM Tristate Bridge. For the top level entity: Open the .vhdl or .v file generated by the SOPC, find for your system, see the code generated and set according to it.
