15 years agoUrgent: Dma
I have problem with DMA. I have lost idea of how to debug anymore. My DMA Controller setting in SOPC is Width of the DMA Register Length is set to 32bit and the rest is left at default. However, m...
15 years agoI have the exact same problem.
The DMA stucks with 4 Bytes left in the Length-Register. This will end in an infinite loop. Are there any issues in the Q10.1 DMA? ------------ code ----------------- IOWR_32DIRECT(DMA_0_BASE,0x04,FIFO_INTERFACE_BASE); //Readaddress ist FIFO IOWR_32DIRECT(DMA_0_BASE,0x08,ALTMEMDDR_0_BASE); //Writeadress IOWR_32DIRECT(DMA_0_BASE,0x0c,ALTMEMDDR_0_SPAN); //Length IOWR_32DIRECT(DMA_0_BASE,0x18,0x18c); //Start Read from Constant adress, write to ddr while((IORD_32DIRECT(DMA_0_BASE,0) & 0x01) != 0x01); //Test Doine-Bit ---------------- code end -------------------- Its an Memory Filler... My Programm and data is in onchip ram. Why does the DMA ends with rest length 4? Marco
