14 years agoUnused IO Banks
If im not using any pins on a IO Bank do i need to connect up its IO VCC? or can i leave this bank completely un powered? Regards Russell Pirie
14 years ago --- Quote Start --- im going to be programming the fpga using a micro controller when the board boots up, so no need for JTAG. although would you recommend having a header any way just incase? --- Quote End --- The JTAG interface is; 1) A programmer 2) A communications interface 3) A logic analyzer interface 4) A NIOS processor debugger interface 5) A custom JTAG interface .... and many more The passive serial interface is *only* a programmer interface. You need it to program you device at power on. The JTAG interface is for all the problems you haven't thought of yet :) Cheers, Dave
