14 years agoUnused IO Banks
If im not using any pins on a IO Bank do i need to connect up its IO VCC? or can i leave this bank completely un powered? Regards Russell Pirie
14 years ago --- Quote Start --- but it would be nice to add a JTAG header to that system as well so i can quickly test new designs, and only use the boot off the micro controller once im happy and the board works standalone --- Quote End --- Yes, so you have already answered the question yourself. --- Quote Start --- can the two be combined? i had a quick read of the AN 250 doc but could not find any examples of boot from micro controller combined with JTAG or AS header --- Quote End --- JTAG configuration and debugging functions are available in any configuration mode. AS mode is alternative to PS. You need switches or jumpers for MSEL to select between both.
