19 years agoUnexpected error in JTAG Server
I was wondering if any has run into this problem. I'm using the JTAG server to program the FGPA's on my board. When start the Programmer I keep getting this error at random "Error: Unexpected error i...
19 years agoravindrasor
If you have a dev board or some other Altera device and you can program that ok, then It's probably something to do with the board or how you have connected the JTAG chain up. I have never used more than two devices in a chain (flex 8k), and then I used a micro to configure them. You could try 'disconnecting' each stratix in turn and try to configure them independently to start with.... HTH
