IMura
7 years agounderstanding the transceiver "RX word aligner pattern"
I am using the Arria10 transceiver using the standard PCS, 8bits FGPA/Standard PCS int width and 10 bit PCS/PMA int width. Other parameters as follow : 10b/8b Encoder and decoder enabled Rx word a...
CheepinC_altera
7 years agoHi,
Thanks for your update. Glad to hear that you have managed to resolve the issue. I would set this case to close. Thank you very much.
