14 years agoUnable to configure a slave Stratix in PS mode from an EPCS64
I have a system consisting of a Cyclone IV GX and a Stratix of the first generation (EP1S25B672C6). The configuration device as an EPCS64. The GX is the master of the configuration chain, with the MS...
13 years ago --- Quote Start --- jp, did you find the solution to your problem? I have a very similar problem except the device I'm trying to configure using PS is a Cyclone IV. I can see the clock and data going, but no cfg_done response. Thanks --- Quote End --- Unfortunately, I have not found a solution yet. However, with Cyclone IV as a slave device in PS mode, I did not have this problem. Regards, JP
