15 years agoUDP offload design example
Hello, I am trying to use the UDP protocol to send the Ethernet packets from a transmitting embedded system to a receiving one. I started by trying to run the offload design example using ...
15 years agoI can't shake the errors coming from the menu.h; all the externs in that file come up as undeclared either in normal errors or makefile errors.
They are externs to functions which exist in the menus.c located bsp/iniche/src/h. I'm really stuck here and desperate for assitance. Do the iniche menus need intitlising in the BSP. I've scoured all the settings 3 times and can't see any settings intuitively named in regards to menus; i've also scoured the 9.0 version html bsp summary and no luck either. I must be missing something. Please help someone
