15 years agoUDP offload design example
Hello, I am trying to use the UDP protocol to send the Ethernet packets from a transmitting embedded system to a receiving one. I started by trying to run the offload design example using ...
15 years agoHow did you go with this?
I'm trying to do the same thing. From experience i know you definatelyu have to re-create the BSPs in Nios when porting old projects. But i've never done this scripting before to get a quartus project, i'll donload old quartus when i get a chance. If i change the script in the src tar, all i'd be doing is disabling the check right? I imagine the check is there for a reason.
