15 years agoUDP offload design example
Hello, I am trying to use the UDP protocol to send the Ethernet packets from a transmitting embedded system to a receiving one. I started by trying to run the offload design example using ...
15 years ago --- Quote Start --- How I'll modify to work on version 10.0sp1? --- Quote End --- I don't know. I would expect changes in the BSP "patch" files. I'm not sure what else. Start with 9.0... When you want to go to 10.x, try building from scratch with the "src" tarball. There are scripts included in that tarball which automate most everything. Cheers, slacker
