15 years agoUDP offload design example
Hello, I am trying to use the UDP protocol to send the Ethernet packets from a transmitting embedded system to a receiving one. I started by trying to run the offload design example using ...
15 years agoIf you're trying to use any of iniche's demos or anything that uses their CLI menu system, you need to ensure that you add the right CFLAGS to make it build.
Perhaps, if you explained more about what you're trying to do, we could help. Regards, slacker
