15 years agotwo tse_mac for DE2-115
Hi all,
I use a DE2-115 from terasic which has two ethernet ports and I want to use them simultaneously. My question is If I use ONE CPU, TWO TSE_MAC in the sopc design, for instance, tse_mac0 and tse_mac1, how should I choose which port I will be using in the Nios simple socket server template? (In system.h, there are configurations for tse_mac0 and tse_mac1 both, but it it turns out that I can only make port0 work) Or should I make two cpu for this kind of design? P.S My data go directly from the physical layer, so the nios is only used to intialize the chip.1 Reply
Hi Bingomickey,
I've just gotten a De2-115 and i'm trying to get ethernet going. The webserver example doesn't work (i'm still goggling this one). Are you able to point me in the right direction so i can get learning? Or do you have code that works, so that i can learn from it?
