15 years agotwo kits connection trough ethernet
Hi all,
My application is video led display panel, I use two EP3C120 development kits to implement this application where one of them is transmitter where it use DVI Daughter card to capture the video frames to send this video frames through Ethernet cable and the other is receiver to receive the video frames through the Ethernet and display this frames on the led panel. this application is working properly when I connect the two kits directly with Ethernet cable but the problem is that the application doesn’t work when I connect the two kits through switch or router. Kindly advice me regarding this problem. best regards2 Replies
thx for your reply
kindly find the hardware and the software for the transmitter card and receiver card best regards - Altera_Forum
could You host the project somewhere to check the source? Provide more information. How did You implement the data sending through ethernet?
