15 years agoTSE TX SGDMA problem
Hi I had triple speed ethernet working in a system. I then added a PIO to the SOPC system, reasigned addresses and IRQs, regenerated and recompiled in Quartus. The ethernet is no longer working...
15 years agoYou could add a printf call in your main file to print out the base address of the SGDMA as defined in system.h, to check that it is the same than in your Sopc project, because it looks like there in a mismatch there.
Are you sure you generated the bsp with the correct .sopcinfo file, and that the image in the FPGA is the right one?
