15 years agoTSE, nichestack tx from fixed location
i am using a design example where the tx sgdma is getting its data from an sdram. i start it all with the sendto() function. problem is the data i want to send comes from a fifo, and so it seems a de...
15 years agoYes it is possible but in that case you need to bypass the Interniche stack and directly setup and use the SGDMA from your code.
