15 years agotriple speed ethernet without external memory
Hi, I have custom board, it consist of no memory devices on board, and need to communicate with host through ethernet port only. Can somebody help me in how to configure TSE without external memor...
15 years agoYes, I built simple socket server example, it requires 376 KBytes of memory (size found out using nios-stackreport) for code. So memory is not a problem, I can use onchip memory of size 512 KBytes (ofcourse more also possible with M9K). Can you explain, what are all the components required and their interconnection in SOPC builder? If possible, can you send me printscreen shot of SOPC window?
Thanking you. Sincerely KMK
