15 years agotriple speed ethernet without external memory
Hi, I have custom board, it consist of no memory devices on board, and need to communicate with host through ethernet port only. Can somebody help me in how to configure TSE without external memor...
15 years agoSince you have the Nios processor you can try and use an operating system such as uc/OS with the Interniche TCP/IP stack and see how much memory it needs. You can compile the sockets server example and check that the on-chip memory you used is enough.
