15 years agotriple speed ethernet without external memory
Hi, I have custom board, it consist of no memory devices on board, and need to communicate with host through ethernet port only. Can somebody help me in how to configure TSE without external memor...
15 years agoThank you very much for response, board consists of EP4SE230k (Stratix iv), I am using onchip memory (M9K) as memory for Nios processor. I am a beginer to this environment, I am explaning here, what is the task to be done through ethernet port, I am running some DSP algorithms (filtering, FFT, decision logics) using IP cores and some custom logic. I need to send control information from host PC to FPGA, as well as need to receive the processed results from FPGA to host PC. Now, can you suggest me best or better approach?
Thanking you Sincerely KMK
