17 years agoTriple Speed Ethernet (TSE) MAC without/built-in PHY
Hi Everyone, I was wondering if there is an alternative to built a system to use ethernet 1 Gbps only without or buillt-in quartus PHY. The TSE uses PHY to make the ethernet signals. I think ...
13 years agoYou might get better luck with some gurus answering by creating a new topic instead of this old one.
For what it's worth, I haven't done what you would like, but I believe it is done commonly in backplanes. Here is one semi-relevant appnote, your application is Figure 2, substituting another FPGA instead of the SFP like in Figure 10. http://www.altera.com/literature/an/an518.pdf Good luck!
