13 years agoTriggering device reconfiguration from inside a Stratix IV?
Is there a way to trigger a Stratix IV device to reconfigure itself from an active serial (EPCS) device without using an external CPLD to toggle the reconfiguration pins? I know there's an ALTR...
13 years ago --- Quote Start --- Is there a way to trigger a Stratix IV device to reconfigure itself from an active serial (EPCS) device without using an external CPLD to toggle the reconfiguration pins? --- Quote End --- On an existing board, or are you trying to design such a feature into a board? If you were to drive nCONFIG low, I suspect you could trigger a reconfiguration sequence. Cheers, Dave
