CLa_R
7 years agoTransmit on UART from FSM
This is a generic problem with VHDL and no for a specific FPGA device. For now, I use a Cyclone IV FPGA. I have created a FSM and I would that, for each state of FSM, to transmit a char (8 bit) fro...
Abe
7 years agoTry out this code and see. Its a simple UART implementation..
-- Very simple, non-buffered implementation of 8 data bits, 0 parity, 1 stop bit
-- serial communications channel. Should be able to work at any baud (with a
-- degree of error) by setting I_clk_baud_count respectively:
-- For a 50MHz I_clk:
-- I_clk_baud_count := X"1458" -- 9600bps
-- I_clk_baud_count := X"01B2" -- 115200bps
-- To generate other timings, perform calculation:
-- <I_clk in Hz> / <expected baud> = I_clk_baud_count
-- 50000000 / 9600 = 5208 (0x1458)
-- Inputs/Outputs:
-- SYS:
-- I_clk - system clock - at least 16x baud rate for recieve
-- but can be less if only using TX.
-- I_clk_baud_count - the number of cycles of I_clk between baud ticks
-- used to set a known transmit/recieve baud rate.
-- I_reset - reset line. ideally, reset whilst changing baud.
-- TX:
-- I_txData - data to transmit.
-- I_txSig - signal to transmit (deassert when txReady low) or
-- change I_txData to stream out.
-- O_txRdy - '1' when idle, '0' when transmitting.
-- O_tx - actual serial output.
-- RX:
-- I_rx - actual serial input.
-- I_rxCont - receive enable/continue.
-- O_rxData - data received.
-- O_rxSig - data available signal - does not deassert until new
-- frame starts being received.
-- O_rxFrameError - Stop bit invalid/frame error. Deasserts on next receive,
-- but the data received may still be invalid.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity uart is
Port (
I_clk : in STD_LOGIC;
I_clk_baud_count : in STD_LOGIC_VECTOR (15 downto 0);
I_reset: in STD_LOGIC;
I_txData : in STD_LOGIC_VECTOR (7 downto 0);
I_txSig : in STD_LOGIC;
O_txRdy : out STD_LOGIC;
O_tx : out STD_LOGIC;
I_rx : in STD_LOGIC;
I_rxCont: in STD_LOGIC;
O_rxData : out STD_LOGIC_VECTOR (7 downto 0);
O_rxSig : out STD_LOGIC;
O_rxFrameError : out STD_LOGIC
end uart;
architecture Behavioral of uart is
signal tx_data : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
signal tx_state: integer := 0;
signal tx_rdy : STD_LOGIC := '1';
signal tx: STD_LOGIC := '1';
signal rx_sample_count : integer := 0;
signal rx_sample_offset : integer := 3;
signal rx_state: integer := 0;
signal rx_data : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
signal rx_sig : STD_LOGIC := '0';
signal rx_frameError : STD_LOGIC := '0';
signal rx_clk_counter : integer := 0;
signal rx_clk_reset : STD_LOGIC := '0';
signal rx_clk_baud_tick: STD_LOGIC := '0';
signal tx_clk_counter : integer := 0;
signal tx_clk : STD_LOGIC := '0';
constant OFFSET_START_BIT: integer := 7;
constant OFFSET_DATA_BITS: integer := 15;
constant OFFSET_STOP_BIT: integer := 7;
begin
clk_gen: process (I_clk)
begin
if rising_edge(I_clk) then
-- RX baud 'ticks' generated for sampling, with reset
if rx_clk_counter = 0 then
-- x16 sampled - so chop off 4 LSB
rx_clk_counter <= to_integer(unsigned(I_clk_baud_count(15 downto 4)));
rx_clk_baud_tick <= '1';
else
if rx_clk_reset = '1' then
else
rx_clk_counter <= rx_clk_counter - 1;
end if;
rx_clk_baud_tick <= '0';
end if;
-- TX standard baud clock, no reset
if tx_clk_counter = 0 then
-- chop off LSB to get a clock
tx_clk_counter <= to_integer(unsigned(I_clk_baud_count(15 downto 1)));
tx_clk <= not tx_clk;
else
tx_clk_counter <= tx_clk_counter - 1;
end if;
end if;
end process;
O_rxFrameError <= rx_frameError;
O_rxSig <= rx_sig;
rx_proc: process (I_clk, I_reset, I_rx, I_rxCont)
begin
-- RX runs off the system clock, and operates on baud 'ticks'
rx_clk_reset <= '0';
end if;
if I_reset = '1' then
rx_state <= 0;
rx_sig <= '0';
rx_sample_count <= 0;
rx_sample_offset <= OFFSET_START_BIT;
rx_data <= X"00";
O_rxData <= X"00";
elsif I_rx = '0' and rx_state = 0 and I_rxCont = '1' then
-- first encounter of falling edge start
rx_state <= 1; -- start bit sample stage
-- need to reset the baud tick clock to line up with the start
-- bit leading edge.
rx_clk_reset <= '1';
elsif rx_clk_baud_tick = '1' and I_rx = '0' and rx_state = 1 then
-- inc sample count
rx_sample_count <= rx_sample_count + 1;
if rx_sample_count = rx_sample_offset then
-- start bit sampled, time to enable data
rx_sig <= '0';
rx_state <= 2;
rx_data <= X"00";
rx_sample_offset <= OFFSET_DATA_BITS;
end if;
elsif rx_clk_baud_tick = '1' and rx_state >= 2 and rx_state < 10 then
-- sampling data
rx_data(6 downto 0) <= rx_data(7 downto 1);
rx_data(7) <= I_rx;
rx_state <= rx_state + 1;
else
end if;
elsif rx_clk_baud_tick = '1' and rx_state = 10 then
if rx_sample_count = OFFSET_STOP_BIT then
rx_state <= 0;
rx_sig <= '1';
O_rxData <= rx_data; -- latch data out
if I_rx = '1' then
-- stop bit correct
rx_frameError <= '0';
else
-- stop bit is always high, if we don't see it, there
-- has been an issue. Signal an error.
rx_frameError <= '1';
end if;
else
end if;
end if;
end if;
end process;
O_tx <= tx;
O_txRdy <= tx_rdy;
tx_proc: process (tx_clk, I_reset, I_txSig, tx_state)
begin
-- TX runs off the TX baud clock
if rising_edge(tx_clk) then
tx_state <= 0;
tx_data <= X"00";
tx_rdy <= '1';
tx <= '1';
else
if tx_state = 0 and I_txSig = '1' then
tx_state <= 1;
tx_data <= I_txData;
tx_rdy <= '0';
tx <= '0'; -- start bit
elsif tx_state < 9 and tx_rdy = '0' then
tx <= tx_data(0);
tx_data <= '0' & tx_data (7 downto 1);
tx_state <= tx_state + 1;
elsif tx_state = 9 and tx_rdy = '0' then
tx <= '1'; -- stop bit
tx_rdy <= '1';
tx_state <= 0;
end if;
end if;
end if;
end process;
end Behavioral;
