18 years agotransfer data from computer to cyclone II
hi guys, I am now doing the project with the FPGA . I need to have the input which is format as PCM 8bits and 200khz. That input will be created by the music mp3( 44.1khz and 16 bits) . So i...
18 years agoHello Clark,
the best solution depends on the amount of data and wich kind of memory it is destinated for. To write embedded FPGA RAM, in-system-memory-editor through JTAG is probably the easiest way. Also external memory could be accessed via a virtual JTAG interface. Other interfaces could be used depending on the target systems hardware equipment: Printer port, RS232, SPI, I2C... Regards, Frank
