CStoe2
7 years agoTransceiver in Cyclone V using less then 614 Mbps
Hi all, In a recent project I would like to use a camera with a clock of 290 MHz when using Double Data Rate. The throughput rate is therefore 580 Mbps per channel for a total of 10 channels. Now i...
CheepinC_altera
7 years agoHi Christian,
Thanks for your update. Regarding the timing issue, I could not comment if the PLL can help to improve your existing timing issue. You may try to see if it is helpful. If it does not help, please feel free to let me know. I will try to see if can duplicate a new case from my side for our timing team to further assist you on closing the timing.
Chee Pin
