15 years agoTotal logic elements increasing
Hi, I'm working with EP3C16F484C6, Cyclone 3 FPGA. I wrote a code that has ~24% Total logic elements. When I wrote several I/O names under the entity, port, the Total logic elements ju...
15 years agoNo. This is because you are using Timequest and you dont have a constraints file. This will see if your design can meet the required timing.
It has no effecct on resource usage - only your source code controls that.
