14 years agoToggling switch button to start and pause using logic '0' or '1'
Hi Altera Friends, I have an issue with design of clock. I have written a program for a clock to count from 0 to 9 and returns to zero. I use a switch as start/stop as in std_logic and i want a...
14 years agoif i press the switch button on the altera board down without removing hand, it will purse or stop. if i rmove my hand from the button, it will start counting. I want the state to change such that if i press the switch button and remove my hand it will purse or stop and if i press the switch button and remove my hand next it should start counting.
ce is assigned as start/stop switch button. hope you understand it?
