15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- You will need to design the ADC to Avalon-ST streaming component --- Quote End --- Hi Dave, From your previous post, you said i need to design the input port for Avalon ST? I don't quite know how to start. Can i use PIO core to supply the stream or a DCFIFO(input from ADC and output to ST sink of SGDMA) ? If i transfer from DCFIFO to SRAM, can i use memory-to-memory configuration of SGDMA? Thank you. Michael
