15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years agoNios II and the JTAG to Avalon bridge can access memory mapped slaves since they both contain memory mapped masters. For Nios II you write C code to do this and with the bridge you write .tcl code to run in system console. *Any* properly designed master can access a slave port so you have more options than Nios II or the JTAG to Avalon bridge.
