15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- Read the TimeQuest guide written by Rysc on the Altera wiki: http://www.alterawiki.com/wiki/timequest_user_guide I have some questions for Rysc related to asynchronous interface TimeQuest constraints. I'm putting those questions into a document dealing with SRAM constraints as the example. I'll post that in a day or so when I get it done (the figure above will be in it). Cheers, Dave --- Quote End --- Thanks DAVE!
