18 years agoTiming problems, Help
Hi, I designed a cordic block that has a fmax of 200 Mhz and I have a 18 bits counter that provides the angle for cordic block, this counter has a fmax of 210 Mhz. Here I don't have problems, but whe...
18 years agoCan you do a right-click on the first path and then a List Path. The path details will be broken out below(you can open and close them with the +/- buttons on the left). Then cut and paste all the information into a text file. This is just summary information and doesn't provide enough detail. (Although my original assumptions seem wrong, as I was expecting a clock path issue. You may have a really long datapath, although I can't know for sure without the details.)
