18 years agoTiming problems, Help
Hi, I designed a cordic block that has a fmax of 200 Mhz and I have a 18 bits counter that provides the angle for cordic block, this counter has a fmax of 210 Mhz. Here I don't have problems, but whe...
18 years agoIf you're using the Classic Timing Analyzer, go to the failing setup panel, right-click on the worst case path and do List Paths. The path details will be broken out below. Cut and paste this into a text file and then attach it. That will provide a lot more information we can help with. There are probably a hundred tips and tricks, if not more, most of which won't apply. Being able to analyze a single path and use that as a starting point toward the root cause is an invaluable skill.
