15 years agotiming constraints for EHPI DSP to FPGA asynchronous interface
Hi, I am trying to write timing constraints for connecting a TI DSP, TMS320VC5510A, to a Cyclone IV FPGA. The bus used is EHPI in Multiplexed mode. It looks confusing because the interface is asynchr...
15 years ago:) Hello Rysc,
thanks for your reply....one insight that comes up with your analysis is that ...in my case of a strobed external interface.....the launch / latch clock relationships are: 1) FPGA clock on the register which clocks in the data HAD_REG a clock before the strobe is generated 2) Latch clock for HAD data bus is hds_n (rising edge) .... 3) FPGA clock on the register which clocks in the data HCTRL_REG bits a clock before the strobe is generated 4) Latch clock for HAD data bus is has_n (falling edge) .... There appears to be a multicycle constaint here...the HAD_REG and HCTRL_REG are both clocked in by the fSM a couple of clocks before either of the strobes is generated (again by the FSM). On the READ side (FPGA reads from DSP) the lauch clock is a DSP internal clock, which generates a DSP_READY flag to the FPGA...the latch clock is the hds_n signal, driven by the FPGA FSM after it detects the DSP_READY flag has gone high. So on the FPGA to DSP side i think these constraints should be OK: a) using DSP_TSu and FPGA_to_DSP_Delay_Max (estimated board delays) : set_output_delay -max [expr DSP_TSu + FPGA_to_DSP_Delay_Max] This is the FPGA to DSP setup requirement b) using DSP_Th and FPGA_to_DSP_Delay_Min (estimated board delays) : set_output_delay -min [expr DSP_TSu + FPGA_to_DSP_Delay_Min] This is the FPGA to DSP hold requirement For the DSP to FPGA path: c) set_input_delay -max = DSP_Tco_max + FPGA_to_DSP_Delay_Max d) set_input_delay -min = DSP_Tco_min + FPGA_to_DSP_Delay_Min BUT i dont see now how or why i would also need to use a set_max_delay or set_mn_delay constraint...as you implied here: If you then apply a set_max_delay, the launch edge will become 0, the latch edge will become the -max value, but the oExt from your set_output_delay will be used. So you could use the set_output_delay to say what the Tsu of the external device is, and then use set_max_delay like you are now. (You could also just tighten your set_max_delay constraint by the Tsu amount and get the same results). cheers
