15 years agotiming constraints for EHPI DSP to FPGA asynchronous interface
Hi, I am trying to write timing constraints for connecting a TI DSP, TMS320VC5510A, to a Cyclone IV FPGA. The bus used is EHPI in Multiplexed mode. It looks confusing because the interface is asynchr...
15 years agoIs it a top-level register? I would normally assume there is a hierarchy path to it. (Note that I recommend get_keepers over get_registers. Either should work, but get_registers isn't a true .sdc command and was added by Altera, where get_keepers is more standardized). In TimeQuest go to View -> Name Finder and use that try and whittle down why it isn't matching. Or go to the Technology Map viewer and look for it there. There's a chance it got synthesized out or something, but most likely it's just a name matching issue. Another thought is to run:
report_path -to [get_ports hds_n] -panel_name test and see what is driving it.
