15 years agotiming constraints for EHPI DSP to FPGA asynchronous interface
Hi, I am trying to write timing constraints for connecting a TI DSP, TMS320VC5510A, to a Cyclone IV FPGA. The bus used is EHPI in Multiplexed mode. It looks confusing because the interface is asynchr...
15 years agoI haven't looked at the actual device or constraints, but generally with "asynchronous logic", the strobe should be treated as a clock. Note that if it were truly asynchronous, you wouldn't time it. Just because the clock isn't always periodic, you have a max and min relationship between the data and that strobe.
More often than not, even with the clocks set up, you have setup and hold relationships that are too restrictive, since they assume data is sent on ever edge. So you most likely need to add multicycles to the interface to get the setup relationship and hold relationship correct. (Note that you need to know what it should be before adding multicycles. Then add the MCs to match the requirement). The final thing is adding the -max and -min external delays, which are usually a small component. I "think" this will help, but not having tread the datasheet, may be way off base.
