8 years agoTiming constraints for 2 clocks, phase shifted by 90 degrees
Hello all, I have a design, in which two clocks are used. One main clock and another one with 90 degree fixed phase shift. There are registers that are related to these clocks, for example re...
8 years agoNot if you can achieve regular timing closure between the synchronous domains. The original question makes only sense if this is your intention.
