13 years agotimequest alt_sqrt how to choose properly signals for multicycle
Dear All, I have in my design 2 ALT_SQRTs, which are working in time multiplex to relax the timing. The system clock is 40MHz. When I use the timequest to check for timing, of course it fails, bec...
13 years agoIf you mean that you have applied clock enable at half clock rate then you can apply multicycle to clock enable fanout (see altera example somewhere?)
Remember multicycle would not apply unless you have designed to sample every two clocks by whatever way.
