15 years agoTime delay
Hello I want to create time delay using logic gates (not flip-flops) When I put carry gates, or any other gates, the time analyzer shows 0 delay Can anyone help I can...
15 years agoA useful answer, I hope:
You can apply a 'keep' setting to restrain the compiler from optimizing it away. In VHDL:signal wire_to_keep : std_logic;
attribute keep: boolean;
attribute keep of wire_to_keep: signal is true;
There is similar setting in Verilog. It is 'stuffed' into a comment in the declaration, before the closing semi-colon. wire keep_wire /* synthesis keep */;
AHDL is very Spartan (no pun intended): output = LCELL( input ) ;
