GBusl
7 years agoThe NIOS II is not booting
I am Creating a system of NIOS II that boot from a Qspi flash device and also the code will be copied to a parallel flash device. I am not sure if this is doable. I cannot find an example or a guide...
- 7 years ago
Hi Galio,
Here is the step by step guide, please check the attachment.
this uses the jic procedure to program a serial flash like QSPI.
GBusl
7 years agoThanks a lot Mr Embedded. What you shared solved my problems.
