15 years agotext to mif conversion
Hello, I am looking for something that would convert a text file (with fractional entries), with values to be stored in a LUT, into a mif file with hexadecimal entries. For example, let a fra...
15 years agoi have this full program,its work.but then when i want to change the spesific size,it have the error.
----------------- name = 'image'; img = imread(strcat(name,'.gif')); g = im2double(img); g = g/max(max(g)); rgb = cat(3,g,g,g); imshow(rgb); out = ones(480,640); out(10+(1:460),90+(1:460)) = img; imshow(out); x = out'; x = uint8(x(:)); n = length(x); y = reshape(x,8,n/8)'; z = y(:,8); for i=1:7 z = bitor(z,bitshift(y(:,i),8-i)); end m = 0; n = 1; v = z(1); for i=2:length(z) if (z(i)~=v) m = m + 1; value(m) = v; runlen(m) = n; n = 1; v = z(i); else n = n + 1; end end m = m + 1; value(m) = v; runlen(m) = n; fprintf('total runs %d\n',sum(runlen)); fprintf('number of runs %d\n',length(runlen)); nz = length(find(value==0)); nf = length(find(value==255)); fprintf('zeros %d all ones %d\n',nz,nf); dfv = 255; fid = fopen(strcat(name,'.mif'),'w'); str = 'WIDTH=8;\nDEPTH=38400;\n\nADDRESS_RADIX=HEX;\nDATA_RADIX=HEX;\n\n'; fprintf(fid,str); str = 'CONTENT BEGIN\n [0000..%04X] : %X;\n'; fprintf(fid,str,sum(runlen)-1,dfv); n = 0; for k=1:length(runlen) if (runlen(k)==1) str = sprintf(' %04X : %X;\n', n, value(k)); else str = sprintf(' [%04X..%04X] : %X;\n', n, n+runlen(k)-1, value(k)); end if (value(k) ~= dfv) fprintf(fid,str); end n = n + runlen(k); end fprintf(fid,'END;\n'); fclose(fid); -------------- can you show me how to make the image 16bits width and 4096bits depth. which part should i alter? thank you.
