10 years agoTesting on unprogrammed blank FPGAs?
as a non-destructive testing, if we want to analyse the un-programmed blank devices for their default output values and also to verify their electrical characteristics as per the data sheet, do any o...
10 years agoA hardware trojan can be implemented by the ASIC designer team of each part. In this case, you cannot verify whether there is a hardware trojan inside your FPGA or not. You could have verified this if you had designed the FPGA (instead of Altera). A hardware trojan may not need any external device for any thing.
