18 years agotest with massive data
Recently I'm writing a decoding module, which needs massive data for accuracy testing. However, inputing these data manually and putting them in the testbench file seems incredible, so I wonder whet...
18 years agoStill you did not exactly told the quantity of data, but you may check if the RAM capacity of your FPGA is enough for your needs. In that case, you may instantiate a RAM block (with enough size) and use it as a ROM (in the MegaWizard procedure you are asked if you want to use it as a ROM and initialize its cells with a numerical file that you can edit).
Hope this helps.
