15 years agoTest 2GB SODIMM with HPCII example driver
I have just brought up my SO-DIMM on Arria II GX using the DDR2 HPCII controller and the Altera-generated HPC1_example_driver Verilog. I'm suspecting that only a fraction of the complete memory is te...
15 years agohi man........
i had a arria 2 gx with 1GB ddr2sodimm but i never use it...... had a example with ddr2sodim at altera wiki or altera forum i guess.... you can use your drive end custumize it for your memory at sopc builder enter in your ddr2sodim drive ...select you memory and click modify parameters ....... and enter with your memory parameters......you can find it at your board user manual............save and recompile..... i think if you changing MAX_ROW, MAX_BANK and MAX_COL can help.... cheers Franz Wagner
