15 years agosystem design using cyclone II
Hi, I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14...
15 years agoHi Dave,
I am now implementing each block unit in quartusII... several questions: 1. the bit width got me a little confused. My input signal is 16bit, I made the NCO generate 16-bit cosine and sine wave. After mixer, I should have two modulated signals of 32bit width. Now, I keep the datapath as 32bit, and input each multiplied result into a low-pass FIR filter(developed through megafunction FIR compiler, single rate, coefficients 8bit width). Should I keep the full precision, which is 40bit length, or should I truncate MSB/LSB? from what I learnt before, the ADC has a Vref=+-2V, 16bit, then the signed fractional representation of the sampled data is (3.13), including the signed bit. I guess from NCO, the cosine & sine wave is (1.15), so after mixer it is (4.28). And after FIR the full precision is 42bit, I can keep the first 16bit if my output resolution is 16bit. right? 2. The filtered result will be squared and summed and take the root. How can I decided the bit length then? Thanks! Allison
