15 years agoSynchronous Design Timing (VHDL)
Hi All, I am very new to VHDL and working with hardware so I'm hoping this forum can fill in some of the giant holes in my knowledge. My current question relates to timing in synchronous d...
15 years agoImplement your logic to operate on the rising-edge of the clock.
The FIFO Megafunction guide comes with some examples. Learn how to use the Modelsim simulator, and write a testbench to test your logic. If you are not sure how to write a testbench. Explain to me what you want to do with the FIFO. I have some FIFO testbenches that I can modify to show you how they work. This testbench would be used with Modelsim, and would be in VHDL, so you can use the Altera-Edition. Download it and go through the Modelsim tutorials if you have never used it before. Cheers, Dave
