synchronize pll
On CycloneII, is it possible to re-synchronize or start a pll on an async event such as a pulse?
I have a 50Mhz pll clocked state machine that is triggered from a single external async pulse. I also have a Flash A/D that is running on a separate, continous 10mhz pll clock. What I would like to do is synchronize the two plls such that the A/D clock is aligned to my external pulse so its sampling times are predictably synched to my state machine logic. The A/D is designed to operate from a continuous clock only and has an internal 4clk conversion delay. The very first result may be bad but I can live with that. I thought of using counters to generate a 10Mhz clock directly from the 50Mhz state machine logic but it would be better if I could use a pll so as to have some control over phase.14 Replies
It is from external equipment. This trigger pulse is latched by 50Mhz logic. After latching, the very next clock starts the state machine. I will probably use the digital pll method suggested, or just generate the 10Mhz clock from the 50mhz logic. Counters are simple.
Where is the pulse coming from that would start your state machine? How do you intend to phase align your 50 MHz clock with the 10MHz clock that the A/D is using?
I think, the only suitable solution to synchronize a clock to single pulse is a digital PLL created in your design. But the timing resolution is limited by the reference clock, could be up to 300 or 400 MHz with cyclone II.
Look at:
http://www.alteraforum.com/forum/showthread.php?t=1473&highlight=pll This is a sample design I did to have PLLs across multiple FPGAs correlate. I think it might work for what you're doing. (You don't need most of the design, but the idea of using the altclkctrl as a enable is the trick...)
