Sync Resets with Clock Enables
I found more information in the Intel Quartus Prime Pro Edition User Guide, Design Recommendations (UG-20131), for 20.1. Section 1.5.2, Secondary Register Control Signals ...
"If you define a register with a synchronous clear signal that has priority over the
clock enable signal, Intel Quartus Prime synthesis emulates the clock enable
functionality using data inputs to the registers."
"The signal order is the same for all Intel FPGA device families. However, not all device
families provide every signal. The priority order is:
1. Asynchronous Clear (clrn)—highest priority
2. Enable (ena)
3. Synchronous Clear (sclr)
4. Synchronous Load (sload)
5. Data In (data)—lowest priority
The priority order for secondary control signals in Intel FPGA devices differs from the
order for other vendors’ FPGA devices."
In Example 37, they use all of the control signals:
module top(clk, clrn, sclr, sload, ena, data, sdata, q); input clk, clrn, sclr, sload, ena; input [7:0] data, sdata; output [7:0] q; reg [7:0] q; always @ (posedge clk or posedge clrn) begin if (clrn) q <= 8'b0; else if (ena) begin if (sclr) q <= 8'b0; else if (!sload) q <= data; else q <= sdata; end end endmodule
This would not be optimal in an AMD device because the sclr would need to be higher priority than the ena.
After 20 years of Xilinx/AMD, I can't see the advantage of Intel's priority. But I'll have to adapt.
