16 years agoSubscription Edition VS Web Edition of Quartus
For my application, i plane to work with Quartus web Edition, but i have readed that the subscribtion Edition has more option. I don't know if this option are necessary for my application (image Fu...
16 years ago --- Quote Start --- You should have no problem, assuming you're using a supported device, and dont want to use any Altera IP (like a FFT filter for the fusion). Are you planning on writing the fusion algorithm yourself? --- Quote End --- Thanks Tricky for your Answer, i have wrote an algorithm fusion in c for a mikrocontroller, now i would try to do the same in verilog for the FPGA.
